PXI
Share external clock between multiple PXI-5105 boards
I am trying to share the external clock input in the PFI1 channel on the first PXI-5105 with three other PXI-5105 boards on a PXI-1033 chassis.  I have successfully shared the trigger with the other cards using the example  niScope EX Multi-Device External Clocking (TClk).vi.  There is not a specific example for syncronizing the PXI-5105, so I have been trying using the example for the PXI-5102.  The problem does not seem difficult but I am probably missing a simple subVI that links all of them together on the backplane of the PXI chassis.
Does anyone know of an example I should be looking at or how to modify an existing example to have the four PXI-5105 boards share the same external clock?
Thank you in advance.
Message 1 of 1
(3,127 Views)
