PXI
Signal Express V2.0 hangs when I copy large data set to clipboard
I collect two channels with 200k points of data and copy this data to the clipboard by right clicking and selecteing Export.  I then paste it into notepad and save.  When I try to get back to my signal express(SE) session there is no response.  I close SE and try to restart.  SE hangs on the splash screen saying Starting Application.  Restart computer solves problem.  Any ideas?
David
(3,379 Views)
Sorry, wrong board.  I don't see a way to move it tough...
(3,374 Views)
What is the configuration of the computer that you are using, for example, are you using Windows XP, how much RAM does the computer have?  Could you also give some information on the kind of hardware that you are using.  Are you using a multifunction DAQ board?
Does this happen only if you paste your data to notepad?
Thank you,
Raajit L
(3,369 Views)
