PXI
Spreadsheet to Array VI works on 6i not 6.1 WHY?
The above question is actually all I needed to express myself. So this shouldn't be required.
Tim Burroughs
email:tburroughs@labratsengineering.com
email:tburroughs@northropgrumman.com
(3,522 Views)
Tim,
I am still looking into this issue as to why you had to redo the enumerations that you were using in your example VI. However, we can at least consider the issue at a workaround state.
Randy Hoskin
http://www.ni.com/ask
(3,522 Views)
The solution is easy but a hassle none the less. I just recreated the enumeration in the 6.1 version and all problems solved. The bad thing about this bug is, The program is vcery large and there are several enumeration that have to be replaced now.
Tim Burroughs
(3,522 Views)
The answer was the enumeration feeding the Spread sheet to array gets corrupted some how
Tim Burroughs
(3,522 Views)
