PXI
What is the maximum number of PXI chassis someone is using
I have three chassis working using windows 2000 and labview but when I try to connect a fourth chassis some cards are no longer detected and I run out of memory
(3,268 Views)
I guess you have a PC with a MXI-3 board and you are daysi-chaining PXI chassis using more MXI-3 extenders.
A MXI-3 extender is reallly a PCI to PCI bridge. When the PC boots, it sees the PXI chassis as an additional PCI segment. So for the PC, it seems that it suddenly has more PCI slots available.
Each PC will have a definite amount of resources available, and the number of boards that a PC can handle will vary from one computer to another. Because of this, I cannot tell you what is the maximum amount of boards you can use in your PC.
If there are any boards in the first chassis that you are not using, you could try to swap some of the boards in the fourth chassis with some of the boards in the first ones.
Hope this helps,
Claudia Lorente
App
lications Engineer
(3,268 Views)
