PXI
Status Code -233900 on PXI-4065
Hello
I'm having some issues with a new chassis I'm building. PXI-4065 won't be properly recognized in NI MAX.
Current Setup:
Chassis : PXIe-1084
Controller : PXIe-8381
Modules:
PXI-6514 x3
PXI-6515
PXI-2567
PXI-2522
PXIe-2737
PXIe-8431/8
PXIe-8430/8
PXI-4065 - Showing status code -233900
I have tested the module in a working chassis, so the module itself is working properly.
The working chassis is running the same configuration, except the controller used is a PXIe-8360.
So far I have tried the following:
Moving the PXI-4065 module to a different slot.
Fix described here https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Z82SAE&l=en-NO
Fix described here https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-NO
Updated the firmware of the chassis and controller.
Complete reinstall
Any further ideas as to what I can do to get this working?
(1,725 Views)
Update:
I moved the PCIe-8382 card to another computer, and this correctly recognizes the PXI-4065 module.
The motherboard in the computer that does not work is of the type HP 88BE, whereas the motherboard in the computer that does work is a HP 8298.
(1,712 Views)
Most likely you will need to follow the steps in the MXI-Express Compatibility and Connectivity Troubleshooting Guide. As you appear to have already suspected, this type of issue is likely a BIOS or PCIe implementation issue with the computer.
Tobias
Principal Software Engineer
Driver Software
(1,707 Views)
Accepted by ChristofferA
Forgot to update the status here.
I found a solution. Disabling fast boot and bios virtualisation in BIOS fixed the issue.
(1,461 Views)
