It doesn't matter if one board is drived with NI-DAQmx and the other with Traditional NI-DAQ. You just need to route the clock of one board to a PXI trigger line and to specity this trigger line as the clock source on the other board.
To have more information on how to program that, I suggest you to see the following ressources :
- For NI-DAQmx :
. The examples in the "...\CVIxx\samples\DAQmx\Synchronization\Multi-Device" folder
. The tutorial named "Timing and Synchronization Features of NI-DAQmx" on the following link:
http://zone.ni.com/devzone/conceptd.nsf/webmain/2638A8DA4E4CFD1F86256D250070C093?opendocument
- For Traditional NI-DAQ:
. The example attached to this thread.
. The tutorial named "Synchronizing Multip
le Measurement Devices" on the following link:
http://zone.ni.com/devzone/learningcenter.nsf/03f7c60f17aad210862567a90054a26c/a37550bbdb7668d78625685f006b9f90?OpenDocument
I hope this will help you.
Benjamin
National Instruments France
