PXI
TB-2605 Block
Installation Guide for TB-2605 Terminal Block mentions about the Cold-Junction Temperature Sensor circuit, but doesn't tell me where the terminals (CJS+, CJS-) are, which pins # ?.
Dan
(3,550 Views)
 You do not have to connect any external sensor for CJC, and hence you will not have these pins
if u read the manual in detail, you will find that there is an onboard temperature sensor for measuring CJC
All you have to do would be, read this sensor form your application program and use this as the cjc for your thermocouple values
also read this link http://zone.ni.com/devzone/conceptd.nsf/webmain/96C3099472F2940E86257057006CAE8A
hope this helps
Dev
(3,546 Views)
Thanks Dev
Dan
(3,536 Views)
