PXI
Test Panel for 6704 no examples?
I'm trying to find an example vi that support our PXI-6704 card. Doesn't seem Ni has any built in, I'm wondering if "Getting started with analog output.vi" will work.
I don't deal with the programming or with the electronics so I'm out of the loop here.
In MAX were using a Remotei-daq config so making a test panel isn't possible.
I need a vi that acts like a test panel and shows what properties can be changed.
Any help at is all is welcome.
(3,300 Views)
Hi JR,
There are lots of examples for this board.  The PXI-6704 will function the same way as any other analog output board.  If you are using LabVIEW, then you can easily find a wealth of examples that can run on the PXI-6704 by opening LabVIEW and going to
Help > Find Examples > Browse > Hardware Input and Output > DAQmx > Analog Generation
Once there you should be able to run any of these examples.
Best of luck,
(3,287 Views)
