PXI
TestStand measuring speed DMM
I am not sure if I put my question in the right place, if not excuse me.
How can I speed up the measurement with the DMM? Usually I read tension and a few weeks ago, the measurement has gone faster.
I work with Labview and TestStand, it runs on the PXI. How can I adjust that?
(2,372 Views)
Accepted by topic author micmai
How about current speed? What is your desired speed?
Is this document helpful for you?
Increasing Your DMM Throughput
Certified LabVIEW Developer
GCentral
(2,299 Views)
Kudos to Emboar, Increasing DMM throughput can be exactly what you're looking for (of course depending on what your question truly is).
Settling and Aperture time also affect the speed of your measurement (with consequences obviously) :
https://www.ni.com/en/support/documentation/supplemental/07/adjusting-the-reading-rate-of-a-dmm.html
Hope this helps.
Patrik
CTA, CLA
Helping (sharing) is caring!
If the post was helpful - Kudo it.
If the post answered your question - Mark it as Solution.
(2,258 Views)
