PXI
The phase consistency cannot be guaranteed when measured multiple times using VST-5644
I have two VST-5644 modules for measurement. I found that the phases of the received signals are different every time with a 'init, fetch data, abort' loop. My preliminary judgment is that repeated ‘init and abort’ cause the RF front end of the VST to mix different initial phase each time.
I don't know any good way to get the initial phase of VST or maintain the same initial phase every time for calibrating the received signal.
Thanks a lot!
Message 1 of 1
(1,103 Views)
