PXI
Unique identification for PXI system
I am looking for a method to get a unique identification of a PXI system like the serial number or the mac address.
I do not want to get the serial number of any of the I/O cards in the system but of the controller itself.
If this is not possible, is there a way to retrieve the mac address or any other unique information?
I need to have this information available in my application to enable/disable some functions of the application.
Thank you,
Christian
(3,669 Views)
Does nobody has an idea how to identify a PXI system?
(3,624 Views)
Hi ChristianEC,
unfortunately there will be no chance to get the information that you want directly like the serial numbers of your cards.
There might be a chance to get the information via ActiveX and some MAX properties. The idea is to read the information from MAX, but unfortunately I didn't have the time to check this in detail.
Another solution could be to "ping" the PXI-systems from your host computer and to get the information as a result. For sure, this method only works, if your PXI-systems have static IP-adresses.
District Sales Manager
(3,617 Views)
Thank you oyster.
I will check if I could use the IP-adress.
Christian
(3,614 Views)
