PXI
Unknown channel or repeated capability name
I want to connect NI PXIe-5451(waveform generator) and NI PXIe-7966R(Flex RIO) with peer to peer technology. I took an example from NI FGEN, which is working perfectly, but when i use it in my project there is an error occures - "unknown channel or repeated capability name". What should i do to fix this problem?
(4,628 Views)
Accepted by bahec666
I saw this post in another location, and there was a suggestion to reorder the properties in your node so that 'Active Channel' is the first.  As mentioned on that post, property nodes execute top down and you may need to specify the channel before enabling peer to peer.  Have you gotten a chance to try this yet?  Do you still see the same error?
Jon F.
Technical Support Engineer
(4,568 Views)
