PXI
Updating LabVIEW in NI PXIe- 1062Q
Hello!
I am trying to use NI DCpower drivers to access the pallettes to control the SMU port in the PXI 4130. The chassis currently runs on Windows 7 with Labview 2011 SP1 installed. But, for DCpower drivers to work, the LabVIEW software at least requires a 2009 version. So, as Windows 7 is compatible with Labview 2018, I was thinking it to update the LabVIEW. Can anyone suggest me how to do it with and without using an internet connection? Thank you!
(2,084 Views)
Hi Muhaisin,
So LabVIEW versions are available for download at the link below. Both online and offline installers are available on this page. However, unless you are a member of our Standard Service Program, you will not be able to download older version than the latest, which is 2019. In addition, unless you have subscription to that Standard Service Program, you would need to purchase the new software to be able to use it.
Download LabVIEW
https://www.ni.com/en-us/support/downloads/software-products/download.labview.html#305508
Best,
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(2,024 Views)
