PXI
Using PXIe 8234 as a EtherCAT Master
Hi every on
I'm using PXIe-1062 chassiss +  Real-Time PXI controller
Can I use PXIe-8234 dual poGigabit Ethernet Interface as a Master EtherCAT?
(3,008 Views)
I am afraid that you can't use the PXIe-8234 as the EtherCAT Master. Thanks!
(2,991 Views)
Thanks for your reply.
There is an another option for us. based on this link (https://www.ni.com/en/support/documentation/supplemental/18/topology-for-ethercat-network.html#secti...) we can use PXI-8234 in a Ring topology. actually I doubt this NI recommendation.
Is it possible or Not?
I know that PXI-8234 is not mentioned in NI-Industrial Communications for EtherCAT® 19.0 Readme file (reference: https://www.ni.com/pdf/manuals/374786l.html)
(2,964 Views)
Hi M.Javad,
Embedded Real-Time Controllers with three or more Ethernet ports can be used as a Ring topology. So, the PXI-8234 can be used in the Ring topology.
Thanks!
(2,912 Views)
