PXI
Using NI PXI-4472 to take presure data
I am new to the National instrument hardware, the module i have  is the NI PXI 4472, and i want to know if i can  use this module to collect data from a  Endevco 8511 pressure transducer?
(4,836 Views)
Hello RDonet,
You can use this module to take pressure measurements but they will not be accurate since this module is designed to accurately acquire changing signals. A module you may be interested in is the PXI-4330 which is a bridge module made specifically for taking strain and pressure measurements.
-Regards,
Product Marketer
(4,817 Views)
