PXI
Using PXI 6251 counter to delay a trigger on PXI
Hi at all,
I need to synchronize some devices on an PXI chassis. Basic operation is a user waveform generation on a PXI5401 that routes the Trigger Signal for the generation to one of the PXI (RTSI) lines. I'd like to use this trigger signal to start a counter on a PXI 6251 counting the PXI 10MHz Clock. No problem so far ( at least none that I see 🙂 What I need is a possibilty to set another sync signal as soon as a certain counter value is reached in order to use this signal as a delayed trigger signal. Is it possible? And how? I've taken a look at the LabVIEW Example finder, but haven't found an example yet...
Thanks!
Oli
P.S. Using LabVIEW 7.1.1, NIDAQ7.4 and a PXI 1042 via MXI4
Message 1 of 1
(2,887 Views)
