PXI
MAX cannot see PXI-8252
Hi all,
I have NI PXI-1042 with PXI-8187 and PXI-8252. In MAX-Devices and
Interfaces I
cannot see 8252 (port 2 empty). I tried to uninstal and reinstall 8252
(add
hardware).
Thanks in advance.
(3,607 Views)
The driver for the PXI-8252 is included natively in Windows. Since NI does not provide the driver for this board, the board will not appear in MAX.
Does the PXI-8252 appear normally in the Windows Device Manager? Are you able to communicate to 1394 devices?
If you connect a 1394 device for which NI does provide the driver, that 1394 device should appear in MAX. For example, if you connect a 1394 camera that is supported by NI-IMAQ for IEEE 1394 then the camera should appear in MAX.
(3,604 Views)
PXI-8252 appears normally in Device Manager, and my camera is in MAX. I thought that something is wrong because PXI-8252 is not in MAX. Thanks for help.
(3,597 Views)
