PXI
Using PXI trigger to synchronize controller with fpga
Hi
I have a 8108-controller and a 7852R fpga in a 1062Q-PXI-Chassis. And I would like to run a timed loop on the controller synchronously to the fpga. But I'm not getting anywhere. There are several things that might be usefull:
1. There is a Chassis-clock. But I only manage to access it on the fpga
2. There are chassis trigger lines (is that the same as PXI-Trigger bus?). Also I only mange to access them on the fpga
3. There a trigger input/output on the front of the controller (which I might be able to connect to the clock output of the chassis). But I don't manage to access it in the software.
Can anybody give me a hint on how to achieve my task?
Thanks, Thomas
(5,758 Views)
Hi Thomas,
a very good question!
I think in general this is not possible to rout directly the PXITrigger Line. Normally is it be done over a DAQcard. There you have several methods with the DAQmx driver to route the Tigger line to a task.
What I found is a idea who is realy close to your question:
http://forums.ni.com/t5/LabVIEW-FPGA-Idea-Exchange/Drive-a-host-timed-loop-with-LabVIEW-FPGA-IRQ/idi...
(5,705 Views)
