03-13-2014 10:51 AM
I am trying to correlate digital in and out on a pxi 6289 with the start of analog input from another card. My understanding is that I can export the start trigger signal from the analog input task to a PXITrigger line and then use this line as an input to a Start Trigger block. I assume that each PXI trigger line is the same on all devices so at the moment I have the start trigger signal output to "/PXISlot2/PXITrigger0" and inputted to the starttrig block as "/PXISlot3/PXITrigger0". When I do this I get error 200452 (something along the lines of that the setting does not apply to the task). Am I approaching this correctly? Do I need to configure the PXITrigger lines differently?
Thank you
03-14-2014 03:59 PM
What is the other card that you are using? Can you try running your VI with highlight execution to pinpoint which property node is throwing the error that you've mentioned?
