PXI
Veristand_NI-XNET Bus Monitor
Goodmorning I am using NI-XNET Bus Monitor from Veristand and I want to read CAN message, from PXIe-8510. If I display the message without Assign Database Alias (Screen1), then I have the column Frame Name (Screen2), but I can't see nothing: the name of the message is not appearing. If I Assign Database Alias, then I don't have the column Frame Name (screen3). How can I see the Frame Name, when I set a database alias? Or there is another method to decode the message? Thank you
(1,066 Views)
Hello merlo21
This behavior is expected - the real-time distribution of the NI-XNET Bus Monitor is not capable of displaying frame names based on a set database alias.
The RT Bus Monitor does not have the same suite of features as the local/PC distribution of the software and is additionally unable to display frame history or comments on specific frames from a set database alias.
Edgar Umrikyan,
Staff Technical Support Engineer
NI
(993 Views)
