PXI
What's the easiest way to add USB ports to a PXI
I did a quick search and didn't find any PXI cards with USB ports. I have an old PXI-8176 and I'd like to add a few more ports to it. Without a hub, what's the easiest way to do this.
CLED (2016)
(6,294 Views)
There is not a way to add extra USB ports to a PXI-8176 without using a hub. The only option you have is to try and find a third-party PXI module that has USB ports. I've looked online and all I can find is a third-party PXI controller with 6 USB ports. It is called the "Cool One" by General Micro Systems INC.
Thank you
(6,286 Views)
As PXI is built upon the CompactPCI standard, you can use compactPCI boards in a PXI chassis.
A quick google search of "compact pci usb" yielded the following:
EKF CompactPCI USB Controller
CompactPCI USB Host Controller Index. ... HTML documents available here. CB2- PIPE CompactPCI 5-Port USB 2.0 Host Controller. USB Controllers from EKF ...
www.ekf.de/c/cusb/cusb.html - 7k -
The UH101 USB Host Controller is a compact PCI module providing USB peripheral connectivity to a host computer module on four front panel connectors.
www.acquitek.com/uh101/cpci-usb-host-controller.html - 29k -
I have not used these boards and can not guarantee their quality, but this should help get you pointed in the right direction.
Matt F
(6,234 Views)
