PXI
Where to find connectors for PXIe plugin card
Can anyone help with information about XP4/XJ4 connectors for PXIe: Suitable vendor type numbers?
We want to make a custom card to plug into a PXIe-1071 chassis - but only need the 3.3V power from the chassis. But after long search I was unable to find a type number for such a connector. XJ4 is the smallest but obviously any of the connector types will do as they all have power pins.
(7,798 Views)
Accepted by topic author heel
Hello heel.
I have searched in our internal papers, and according to my findings we are using ERNI as a manyfactor for our connectors.
ERNI
Also, since you want to design for own PXI board, you might be able to find some usefull information in the PXI specifications.
PXI Systems Alliance
I hope you can use this information.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(7,687 Views)
Thanks Alex,
Your information is very appreciated.
(7,680 Views)
Glad I could help Smiley Happy
Best Regards
Alex E. Munkhaus
System Engineer
(7,678 Views)
We are about to make some PXIe to PCIe adapters but after checking with ERNI, TE Connect and many other (Googling, etc..), i haven't been able to find a XP4 connector that is right-angled. ERNI only have vertical connector that fits on a real PXIe chassis backplane which won't fit for simple straight pcb PXIe to PCIe.
Any hints for such connector ?
See image of similar PXI to PCI adapter that we want to reproduce for PXIe...
(4,199 Views)
