12-18-2006 11:10 AM
12-19-2006 01:40 AM
If you choose a switch with a bandwidth say double of your baudrate it should not be a problem. Beside that in a testsystem you work with short cables so there is not much load to see for the driver.
I have a RS-485 application. To reproduce faults from the field I sometimes try to get the interface to fail wil resistive and capacitive loads. Try it you will be amazed how long it will work. ![]()
If the design fails because of the load introduced by the switch then I don't think it is gonna work in the real world with bad cables and/or connected devices. ![]()
