PXI
Why can I not find my hardware of RT system in MAX?
My test sytem include RT system based on PXI bus and Windows system installed in industrial PC.They are connected by LAN.
After I install the RT system and drivers, I can find all hardware of RT system through Remote system in MAX. But if I replace my hardware or controller in RT system.Always I can not find my hardware in MAX. So I must refresh in MAX continuously until I can find.
(3,233 Views)
s_yy,
Is the problem that you cannot find the hardware in MAX at all or that it requires refreshing for it to appear?
When you change/replace the hardware in your RT PXI system, you have to refresh the view in MAX in order for it to detect the changes - this will not occur automatically. You can refresh all items in MAX (View > Refresh) or you can refresh each item individually when it is selected. Keep in mind it may take some time for the hardware to initialize before you can detect it in MAX.
Misha
(2,866 Views)
