PXI
Windows XP 32-bit Virtual Memory Tuning.
For our PXI racks we "tune" the virtual memory under Windows XP 32-bit (standard NI installation), as a couple of our applications process vast volumes of data , as follows:
Open boot.ini
Find the line beginning with 'multi'
Add the following to the end of the line '/3GB /userva=2560' (without the quotes).
Initially we were supplied with PXIe-8133 driven PXI racks and the above change works perfectly.
However later PXI racks were supplied with PXIe-8115 driven PXI racks.  If the above line is applied to these PXI racks then the result is the graphics card drops to 640x480 4-bit colours and it cannot be changed until the line is removed.
I have tried various values for /userva including 2176, 2432, and 2304 but all results in the same result.
It seems that whilst the PXIe-8133 came with a standard BIOS and hence was configurable to an extent, the PXIe-8115 comes with a NI BIOS and provides very little low level control in comparison.
Has anyone attempted the above on a PXIe-8115 driven rack?  Or can suggest a solution?
Thanks.
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
Message 1 of 13
(8,067 Views)
I have attached the Windows XP System Resource Maps for both our PXIe-8115 and PXIe-8133 racks.  Both racks contain the same hardware in the same slots (apart from the controller card).
Christopher Povey
Message 2 of 13
(8,059 Views)
Hi Christopher,
Are you able to tweak the virtual memory using the first method listed on this page?
http://www.wikihow.com/Fix-Virtual-Memory
Kind regards,
Matt H
National Instruments UK
Message 3 of 13
(8,023 Views)
@MHutch wrote:
Hi Christopher,
Kind regards,
It is set to the maximum of 4096MB.  However I don't think Page File size would stop Out of memory errors when LabVIEW is processing vast amounts of data (say from an ARB card for example).
Christopher Povey
Message 4 of 13
(8,020 Views)
Hi Christopher,
Are you able to confirm the amount of RAM you have installed in each of these controller types?
Kind regards,
Matt H
Message 5 of 13
(8,017 Views)
@MHutch wrote:
Hi Christopher,
Kind regards,
The "problem one" PXIe-8115 has 4GB DDR3 single channel memory fitted.
I'll check the PXIe-8133 one once it is free.
Christopher Povey
Message 6 of 13
(8,011 Views)
Thanks Chris, it would be good to compare.
It sounds like you are reserviing too much memory on the 8115 for the video driver to be able to function properly. I'll look into comparing the base specs of the two machines, but if you could provide the RAM information of the 8133, that would be very helpful.
Kind regards,
Matt H
Message 7 of 13
(8,009 Views)
Kind regards,
Ok,
PXIe-8133:
CPU-Z* is reporting: 3248MB. Channel = Dual.
Windows System Properties Reports: 3.17GB
PXIe-8115:
CPU-Z is reporting : 4GB. Channel = Single.
Windows System Properties Reports: 2.91GB
* CPU-Z software on the PXIe-8133 the NB Frequency and DRAM Frequency are changing slightly as I observe... 😕
Christopher Povey
Message 8 of 13
(8,007 Views)
Can you tell me what you stats you get for each using MsInfo32?
You can access this by
1) clicking Start > Run
2) type MsInfo32
3) Find the system summary on the main page
Please could you tell me the physical and virtual memory for both of your controllers when you get the chance?
Kind regards,
Matt H
Message 9 of 13
(8,005 Views)
2) type MsInfo32
Kind regards,
PXIe-8115:
Total Physical Memory = 4,096 MB
Available Physical Memory = 2.12 GB
Total Virtual Memory = 2.00 GB
Available Virtual Memory = 1.95 GB
Page File Space = 4.75 GB
The PXIe-8133 I have access too does not currently have the /3GB /userva switch set.  I will add them and then repeat the above for it.
Christopher Povey
Message 10 of 13
(8,002 Views)
