PXI
Windows XP x64 support for NiDAQmx PCI-6601?
We're using the PCI-6601 with Windows XP x86 and we want to move to Windows XP x64.
I notced the following discussion on this forum:
http://forums.ni.com/ni/board/message?board.id=250&requireLogin=False&thread.id=20698
Have there been any updates on supporting XP x64? So far the latest version of the software only supports Vista x64, and we're unable to use that for our application.
Thanks.
Erik
(4,318 Views)
Accepted by topic author Erikburd
Hello Erik,
Thank you for using NI support.  As of now, we still don't have support for Windows XP x64, and because of  the mass amount of Windows users moving from XP to Vista and beyond it's doubtful that we will have support for XP x64 in the future.  As of now, your best bet is to stick with your current OS, or if you must move to 64-bit then, as you already mentioned, we do support Vista x64.  I hope this helps.
(4,312 Views)
Thanks for the update.
Unfortunately, Vista x64 isn't an option for us because Vista has some existing issues that would substantially affect our application's performance. We're disappointed because we really wanted to move to x64, but it would be nice if it was supported.
(4,309 Views)
Another option might be using Windows 7 x64.  I know several companies who are more comfortable moving to Windows 7 and NI-DAQmx 9.0.2, just released, officially supported Windows 7, both x86 and x64.  We've seen very good performance on Windows 7 based test systems internally.  Windows 7 officially releases October 22nd.
Message Edited by Seth B. on 10-09-2009 11:01 AM
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(4,256 Views)
Seth,
Thanks for the update. I don't think we will be going to Windows 7 (I wish!) because of other system performance considerations, but if we decide to later on then I'll definitely try it out.
Erik
(4,253 Views)
