PXI
addressing module on a pxi bus
I just recieved a PXI chassis and I'm trying to set up a project. My hardware includes a 1042 chassis, 8101 controller and (for now) a 6224 M series DAQ. I will be adding additional cards later but for now this is all I want to deal with. I have been working with FPGA projects and I assumed this would be similar (Adding a device and configuring the slots etc.). But for some reason the option to add a device is not present. Am I on the worng track? Does anyone have a tutorial on seting up a PXI project in Labview?
(3,211 Views)
Is your 8101 controller running a Windows OS?  If so, you will program in LabVIEW with DAQmx just like programming in any Windows computer.  See the following links for getting started with DAQmx programming:
Using the DAQ Assistant
DAQ Getting Started
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
If you are running a real-time OS, that is a little different and you should refer to the getting started with LabVIEW Real-Time Manual for help setting up your Real Time project.
Getting Started with LabVIEW Real Time
Jim Schwartz
(3,192 Views)
jschwartz,
Thanks for the links. They will be a big help.
Yes I realized I was making this way harder then it needed to be. I learned Labview while programming the Real Time cRio with FPGA and when I was handed this PXI chassis I assumed it would be similar. Also I discovered that the Labview installation was messed up (all of the DAQMX and DMM drivers didn't install). So now I have the software right and my head right this should be easy.
Thanks again for the help.
(3,188 Views)
