PXI
buffer for continuous acquisition
hi,everyone.I have a PXI-5124 board.I need to perform a continuous acquisition for a signal (frequency at 1MHz,cycle time is 10s).i set the min sampling rate as 5MHz,the min record length as 50Ms.i store the data into the file. I use the queue as a buffer ,but the result is not satisfying. when I run the digitizer for a while, every time it indicated “the memory is not enough”. May I ask the board can achieve the acquisition goal? how should I set the buffer?
(4,692 Views)
When dealing with that much data, I typically just stream the data to a file and then post process as needed.  You are also likely getting into memory issues with your queue setup.  Can you post your code?  There are likely optimizations we can make to get you where you want.
(4,689 Views)
i want to press the "store"button as needed and then store one record into a file.a record includes 20M samples.that's all.
(4,589 Views)
