PXI
cancellation excitation voltage for inductive sensor
 I m using PXI 4496 with inductive sensor (on-off sensor). If i make measurment via analog input instead of triggering channel, is the excitation canceled
(3,175 Views)
Hello Umutozkans,
It sounds to me like you want to be able to turn IEPE excitation on/off on channels.  If this is the case then you can use a DAQmx Channel Property node as shown in these KnowledgeBase articles.
How Do I Enable IEPE Excitation on My DSA Device in DAQmx?
How do I Enable IEPE Excitation Programmatically?
If this isn't what you're looking for could you please give some more details on what you're looking to do.  A data sheet detailing your sensors requirements and a definition of "Canceling Excitation" would be helpful.
Cheers,
Brooks
(3,167 Views)
