PXI
change application mode of 6534PXI card
I want to know if i can change my application mode (Unstrobed IO, Handshaking, change detection) of PXI6534 Card although i use the pattern IO mode for sending tests patterns to a component.
My problem is that i use firstly pattern IO mode to send patterns, but sometimes i need to wait for receveing signals from testing component without lost the onboard memory which has been filling by my patterns that i want sending.
thanks
Hari.
(3,117 Views)
Hi Hari,
What do you mean with "sometimes i need to wait for receveing signals from testing component "?
Regarding the description of your problem I would recommend to use the burst mode for handshaking.
BR, Christian
(3,106 Views)
