PXI
current acquiring with NI PXI 7831R
I am using PXI 1042 for my academic project. My objective is to acquire the leakage current of insulator for analyzing it further.
Initially we tried to use PXI 5112, but could not succeed with it as it is not possible to acquire current waveforms with PXI 5112. The value of leakage current ranges from 0 to 200mA.
My query is whether I could use PXI 7831R for acquiring the leakage current of the insulator, with the range I have mentioned above. Is there any programming or pre-configuration of PXI 7831R before starting of acquiring the current waveform. And also please clarify me about the connectors I need to use.
Thank you in advance.
Message 1 of 1
(2,988 Views)
