PXI
displaying more then one file at a time from the 1042 rt modual/
I have an alarm system with 48 input channels built around pxi 1042 real time system . I have been able to read files  (of alarm states) from the real time modual however I can not get the system to display multiple files at the same time. the system can sense multiple states and writes the files with time stamps. They are simple one line text strings. Any suggestions?
Thanks  Dr. Lee
(3,057 Views)
Hi Dr. Lee,
What type of RT controller are you using? What cards do you have in the 1042? Are you using LabView to program this? How are you reading and displaying the files on the RT module?
I will need more specific info in order to help you out.
Natasa
(3,039 Views)
