PXI
fpga
Hi Could you tell me what is the advantage of FPGA in labview compared to conventional FPGA in paper perspective ?? I am working on MPP tracking.
Regards
Pradeep
(5,044 Views)
Hi Pradeep
If I understand you correctly you're looking for the advantages of coding an FPGA in labVIEW instead of conventionally? The main advantages are the fact that there is no need to learn or code in VHDL or any other hardware description language. This allows people with less understanding of digital hardware design to use products like FGPAs. If I have misunderstood the question or you want any more information post back.
Dan
Daniel Harryman MEng
CLA, CPI
(5,001 Views)
It should be noted here that LabVIEW FPGA does not program any FPGA.  It is for programming NI DAQ and Instruments that have an FPGA on them.
GCentral
(4,996 Views)
But other than this is there any advantage in perspective writing a paper
(4,988 Views)
Here's the product page, I'll let you explore the links and find what you are looking for.
https://www.ni.com/en/shop/electronic-test-instrumentation/add-ons-for-electronic-test-and-instrumen...
GCentral
(4,986 Views)
