PXI
list of not hybrid PXI modules
Is there a list of PXI modules that are not hybrid ? I am considering to get a PXI chassis and interested in using PXI modules only at the moment but I wonder if I get a 1062Q to what extent I will be able use the hybrid slots.
(1,340 Views)
Accepted by metebalci
That kind of list does not exist. Simply because the same model of the module might have a full PXI or hybrid compatible connector. A recently manufactured module might be hybrid compatible and an older full PXI can be reworked to be hybrid compatible. The best is to check the connector before you purchase.
https://tmesystems.net/
(1,309 Views)
