PXI
list of not hybrid PXI modules
Is there a list of PXI modules that are not hybrid ? I am considering to get a PXI chassis and interested in using PXI modules only at the moment but I wonder if I get a 1062Q to what extent I will be able use the hybrid slots.
(930 Views)
Accepted by topic author metebalci
That kind of list does not exist. Simply because the same model of the module might have a full PXI or hybrid compatible connector. A recently manufactured module might be hybrid compatible and an older full PXI can be reworked to be hybrid compatible. The best is to check the connector before you purchase.
https://tmesystems.net/
(899 Views)
