PXI
more than 2 trigger input for the pxi-5422
I use in my program the pxi-5422 with a script mode. But i need 3 trigger and the 5422 have only two.
Can i use trigger of the digital data smb-2163 ? or 3 of the 6 trigger input of the pxi-6653 !
Thanks.
(3,997 Views)
Can you be more specific ?
What kind of hardware do you use ? What do you want to do exactly ? Which softwares are you running ?
(3,985 Views)
hello,
my program ( Labview VI ) is the same then the exemple given by the FGEN (FGEN switch between waveforms.vi).
but the difference is that i want to switch between the waveforms using a TRIG signal not a software TRIG.
the script that i use :
script SwitchWaveforms
   wait until scriptTrigger1
         repeat until scriptTrigger2
         generate Waveform1
         end repeat
               repeat until scriptTrigger3
               generate Waveform2
               end repeat
                    repeat 10
                    generate Waveform3
                    end repeat
end script
so i have 3 waveforms to generate => 3 TRIG signal.
i use the pxi 5422 but it propose only 2 trig input !
i try to use the trig input of the PXI-6653 but dont want to work !
any solution ?
thanks.
(3,973 Views)
Well, if your card doesn't allow more than 2 trigger, you won't be abled to use a third trigger from another card in the same script.
But maybe, you'll be able to use one trigger twice in the same script. Have you tried doing that ?
(3,959 Views)
