PXI
no available switches in new switch executive virtual device
Hi all,
I have a problem creating new switch executive virtual device....
The second screen in the 'create new...' wizard (started from within MAX) has no items listed in the available switches list box, so I cant progress and create the virtual device.
I am using a PXI chassis with a PXI-2565 switch device with the driver installed on the connected PC.  The instrument appears in the devices and interfaces section of MAX under Daqmx devices and I can drive the switches with the Daqmx test panel.
Any ideas anyone?
Cheers
Barry
(3,405 Views)
Hi Barry,
      Have you created the IVI configuration in MAX. You will need to create the logical name and driver session before they will appear in switch exec. Don't forget to save the IVI configuration once created as this is not automatic.
Hope this helps,
  Nick
(3,393 Views)
Hi Barry,
  I beleive the issue is the same as a support call we've had with your colleague Tom.
THe solution was the PATH variable which had been overwritten so it couldn't find the dll's in the vxipnp directory.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,378 Views)
Yes, Thankyou Sacha.
(3,375 Views)
