PXI
profiboard
Hello.
I have a board PROFIboard PB-IF-03/HW  V1.03 and I will  want know how used with labview 2012. Thank you.
(5,400 Views)
Hi AcostaITC.
We do not directly support the profiboard card you're using. However, you can probably still use it with LabVIEW.
You need to install the board's driver on your development computer. If that driver includes a dll you can call (which from the looks of this it does include it) you can call the dll from labview to use the card. To know which functions to call you will need to read the board's manual, which I wasn't able to locate.
The driver also apparently includes an example of how to call the dll. This probably won't be in LabVIEW but the functions you have to call with the call library node are the same as in that example.
If you would like a card with more direct support from us, we have some profibus interfaces as well.
Regards.
Aldo H
Ingenieria de Aplicaciones
(5,380 Views)
