PXI
pxi-2527 connector pins
I am using a pxi-2527 in a test application.
I need to know the pinout-identity of the two signals 1WREF0 and 1WREF1.
Thank you.
Best regards
Jesper Jakobsen
(5,381 Views)
The identity (pin numbers) of these two pins are not shown in the datasheet..!??
(5,372 Views)
Hi Jesper,
You can find the pinout information for the PXI-2527 in the NI Switch help file via National Instruments>>NI Switch>>Documentation>>NI Switches Help in the Start menu. Just do a search for "2527 pinout".
Peter Porsman | Applications Engineer | National Instruments
(5,353 Views)
that's great... what if you are in the design phase and dont yet have the card or the switch software...
can this info be found online?
(4,448 Views)
