PXI
pxi-8174 with pxi-4070 dmm not found
Hi, I'm trying a different way of getting the DMM to work.  It's installed in a PXI-1031 chassis.  I now have a PXI-8174 embedded controller installed in slots 1-3.  In slot 4 I have the DMM PXI-4070 installed.  I loaded the most current driver from the website for it.  Yet the instrument does not show up in MAX.  I am able to use the DMM when installed in a different chassis and computer set up (pxi-1045).  What am I missing?  Thanks!
(3,120 Views)
Crane,
What drivers did you install?  Does the instrument show up in Device Manager?  Did a box come up allowing you to install the drivers and if so did you load the drivers for the device?
Sincerely,
Jason Daming
Applications Engineer
http://www.ni.com/support
(3,109 Views)
