Hi, I'm trying a different way of getting the DMM to work. It's installed in a PXI-1031 chassis. I now have a PXI-8174 embedded controller installed in slots 1-3. In slot 4 I have the DMM PXI-4070 installed. I loaded the most current driver from the website for it. Yet the instrument does not show up in MAX. I am able to use the DMM when installed in a different chassis and computer set up (pxi-1045). What am I missing? Thanks!
What drivers did you install? Does the instrument show up in Device Manager? Did a box come up allowing you to install the drivers and if so did you load the drivers for the device?
Sincerely, Jason Daming Applications Engineer National Instruments http://www.ni.com/support
