PXI
pxi automotive "analog in"
I'm trying to move our company's automotive testing into the 21st century - away from a mess of Measurement Computing and Dataforth modules and into NI PXI system.
Has anyone used PXI to read in 12 to 16 volts signals?  At the moment, I can only find analog-input modules with +/- 10 volt range.  Am I stuck running test signals into Dataforth modules to step-down into +/- 10 volt level?
How critical is the controller?  Can I use a NI PXIe-1073 Chassis with PCI Express Controller and (3m) Cable for 1 millisecond resolution for data collection and control?
Ron
(5,061 Views)
Accepted by mysticfree
Hello Ron,
There are several modules that will fit your needs. Please review the link below. Several of the modules will work for your application. Since you only need to measure voltage between the 12V to 16V range, you only need a range of negative 2 Volts to positive 2V range. The spec sheets will give you the absolute range you can operate the device within.
http://sine.ni.com/np/app/main/p/bot/no/ap/daq/lang/en/pg/1/sn/n17:daq,n21:41,n36:19,n24:PXI-FSLASH-CompactPCI,n23:11502/
The controller is not critical for data collection and control for your scenario. For your application, the module and the chassis will be the critical components.
I recommend contacting the NI sales department to get some great recommendations if you have any additional questions.
I hope this helps!
(5,039 Views)
Hi RZag,
I should have been more specific with the voltage range.  The signals are 0 to 16 volt waveforms.  The analog input modules that I found only have -10 to +10 volt limitation.
I assume there are automotive systems using NI equipment, so I'm wondering what NI PXI devices they use to make measurements.  Or, is there a complete different arrangement for this industry?
After posting my initial message, NI has gotten in contact with me.
And so the adventure continues...
Ron
(5,025 Views)
Hello Ron,
Thank you for your response. The modules for your application will still work if you are measuring analog input voltages between 0V and 16V. The -10V to +10V refers to the voltage range from your voltage reference. If you set your voltage reference at 10V, you can measure voltages from 0V to 20V. Please verify the analog overvoltage protection is within -16V and +16V.
If someone from sales has contacted you already, they may be a great resource to ask about best practices in the automotive industry.
Best Regards,
Richard
(5,017 Views)
(4,722 Views)
Hello Rg,
I just received my PXI system yesterday.  It has a PXI-4304, which covers +/- 42 volts.
Ron
(4,717 Views)
