PXI
sending trigger by the backplane OF PXI
 I try to send trigger by the back plane of the PXIe 5840. when i use the export trigger RFSG block it gives me the below error.
Error -54010 occurred at niRFSG Initiate.vi
Possible reason(s):
An internal error occurred.
Source Device: G2_R2
Source Terminal: ao/0/StartTrigger
Destination Device: G2_R2.
Destination Terminal: ao/0/PXI_Trig2
When i set the output port of trigger to the PFI0 every thing is good but when i change it to the PXI_TRIG0 (backplane) it gives the above error. i set the NI MAX configuration as the picture which i have attached. if you can help me why i  encounter this problem, can help me. should i set the other things for sending trigger by the backplane?
Message 1 of 1
(2,427 Views)
