PXI
timebase and reference clock
What is timebase and reference clock mean inside DAQmx Timing Properties?
How could I generate 80M Hz clock to be synchronized as the backplane clock for all the PXI devices?
Thanks!
(3,299 Views)
Hello Hilary.  The PXI backplane actually has a 10 MHz PXI Clock built into it.  The 80 MHz internal timebase of many of our DAQ cards is too fast to pass through the backplane/ RTSI bus.  There is a great knowledge base article that explains this in great detail at:
Multi-Device Synchronization
The examples embedded in this article use the DAQmx timing property nodes as well so this should be a great resource for you!  Finally, at the very bottom of this page, there is a zip file available for download that contains numerous examples (both PCI and PXI) that deal with multi-device synchronization.  Please explore these to get an idea of what is required to programmatically implement this synchronization.  I hope this resource is as valuable to you as it is to me.  Let me know if you have any questions about it and I will be happy to address them.  Have a great day!
Brian F
(3,286 Views)
