PXI
use "RFSA Acquire IQ Data in Blocks" VI
I wan to run the example "RFSA Acquire IQ Data in Blocks" VI.  It asks for the resource name.
I have a ni5660 = ni5600 + ni5620.  So in MAX ni5600 has an name and can be seen under NI-DAQmx Devices.  But i cant see ni5620 in that section.  I see it under Traditional NI-DAQ (Legacy) Devices and hence I cant give it a name.
Also ni5600 in NI-DAQmx Devices has no Digitizer associated with it.
I went through this link and it was not of much help.  http://digital.ni.com/public.nsf/allkb/ABBB55946EB39A02862571FD0052024C
I am attaching the example and the screen shots on MAX.
(3,274 Views)
Hello Om,
The RFSA Acquire IQ Data in Blocks VI uses the RFSA driver not the 5660 driver.  The RFSA VIs require the 5661 = 5600 and 5142.  Both of these devices are DAQmx devices.  However the 5660 = 5600 and 5620, where the 5620 is only a Traditional DAQ device.  You only have to associate a digitizer with the 5600 if you use it with the 5142 and the RFSG driver.  The behavior you are seeing is expected.
All of the examples you can run will start with ni5660 and perhaps the ni5660 Fetch IQ Data will work for you.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(3,262 Views)
