PXI
what is device nomber of upconverter?
what is device nomber of the upconverter ni-5610?and  downconverter and how to get it from MAX.
thx
(3,372 Views)
  if you open up measurement and automation explorer, they should show up in your traditional DAQ section or the DAQmx section. It depends on what you're combining it with to make the RFSG or the RFSA, (i.e. 5142 or 5620 to make a 5661 or a 5660  and the 5421 or the 5441 to make a 5670 or a 5671 ) and which version of the driver you're using (so in the latest driver, the 5660 has it's own api where you specify the downconverter and the digitizer separately which given your question is what I'm assuming you're trying to do)
http://digital.ni.com/public.nsf/allkb/ABBB55946EB39A02862571FD0052024C
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,362 Views)
thanxs,
it's clear now.
thank u for ur reply.
(3,357 Views)
