Phase Matrix Products
QuickSyn FSL0010
I am using a QuickSyn FSL0010.
I manage to communicate with him via NI-MAX and the VISA test panel.
All commands work except those related to the RF output.
OUTP: STAT ON / OFF -> Does not change the RF output state
OUTP: STAT? -> Returns an error
This QuickSyn is integrated in an automatic test bench, so I must be able to use these commands
Anyone have an idea?
(8,877 Views)
Hello
You can use 02 command to get output state and use 0F01/0F00 to enable or disable the output, see detailed command description in attached screen shots.
Frank
(8,668 Views)
Thank you for your reply.
But I don't want to use SPI commands
I need these functions but with SCPI commands
Vincent
(8,664 Views)
Accepted by AfgVD
Hi Vincent
These two commands also can be used as SCPI, you can try it as showed in attachment. Seems that commands OUTP: STAT ON / OFF and OUTP: STAT? are not supported on FSL-0010, we had the same situation before.
Frank
(8,661 Views)
Hi Frank,
OK, thanks. I'm not on site these days.
As soon as possible I will try
thanks again
Regards
Vincent
(8,639 Views)
Hi Frank
It works with commands 0F01 / 0F00.
Thanks again for your help
(8,587 Views)
