Power Electronics Development Center
9607 stuck possibly due to running out of physical memory
In my program I have a high speed fault buffer that logs a csv file whenever my converter faults. Recently I noticed that the buffer file was getting filled up due to a lot of fault files logged. I have code in there that would delete the files if the memory used exceeds 500Mb but unfortunately I found out that this was too high. My folder balooned to just over 400Mb and now I cannot work with the controller any more. I cannot deploy a new image on it using the RAD utility, neither can I FTP in to delete the files.
Any help or pointers to bring my controller back to life would be much appreciated.
at_BhatPower
Message 1 of 1
(3,095 Views)
