Power Electronics Development Center
HIL using MyRIO keep throwing error
Dear Professionals,
I Gurusamy Pandiaraj have basic knowledge in LabVIEW, I am trying to do Hardware in Loop using myRIO.
Control and Simulation Loop in Run Time VI and PWM generation in FPGA Main VI. when i call FPGA Main VI in Run Time VI by Desktop Execution Node and deploy to myRIO throws and error like
"Deploying niFpgaDEN_CheckControlTypeChange.viniFpgaDEN_CheckControlTypeChange.vi loaded with errors on the target and was closed.
LabVIEW:  (Hex 0x627) The function name for the LabVIEW:FpgaEmulCompareTypes:C     node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
Deploying myRIO-1900 Container
Deployment completed with errors"
What to do with this error?
kindly help me to solve this.
herewith i have attached the project vi files for your reference.
Thank you.
(5,066 Views)
I am experiencing the same exact error and I cant find a solution.
(4,162 Views)
