Quick Drop Enthusiasts
Is it possible to create a QD for "disconnect from typedef" ?
Darren,
Your VI cause LabVIEW crash from time to time.
I finally track it down.
Here is how to reproduce the problem:
1. on the diagram, select the typedef, ctrl-space, ctrl-Y.  Nothing happens.
2. on the front panel, select the typedef, ctrl-space, ctrl-Y, LabVIEW crash.
LabVIEW 2013 SP1 (13.0.1f2) 32 bit, on Windows 7 Pro. 64 bit.
test VI:
ftp://ftp.ni.com/incoming/George.zip
George
George Zou
Message 11 of 14
(1,273 Views)
I tried using your test VI, but I was unable to reproduce the crash with your instructions. I tried 2013, 2013 SP1, and 2014. All 32-bit on Win 7 Pro 64-bit.
Oh, and I didn't include functionality in the plugin to process ControlTerminals, but I imagine that would be fairly easy for someone to add.
Message 12 of 14
(1,273 Views)
Thanks for the quick response.
You are right that it doesn't crash LabVIEW everytimes.
Try this:
1. double click the typedef on the diagram.  This will find the typedef on the front panel.
2. ctrl-space, ctrl-Y, LabVIEW crash.
George
George Zou
Message 13 of 14
(1,273 Views)
zou wrote:
Try this:
I wasn't able to reproduce a crash with these steps either. I tried undoing/redoing as well, no crash.
Message 14 of 14
(1,273 Views)
